How to get mimaki Rasterlink pro 3 to work on windows 7 on 64 bit
oggy
Hi everyone
I have rasterlink pro 3 and was told I had to upgrade to version 5 to be able to use it on windows 7 64 bit.
After hours of trying to figure out how to make it work I found a way. Just like to share it here.
1. Install Rasterlink pro 3 as normal.
2. Download the latest printer drivers from mimaki (For JV33 mine was mkdriver_v340.exe) and install them
3. When you try and register your printer in the printer manager utility it will show an error like "MMK RLP
port" or something.
I think the problem is that rasterlink can't create the RLP port on windows 7 or something but I'm not too sure.
Anyway, what you do is copy these two files from your old windows xp 32bit computer, the file names are
RlpMon.dll and RlpMonUi.dll located C:\WINDOWS\system32. Paste these two files on your new computer here
C:\RstrLink\Hot\
The MMK RLP port error will go away.
I don't know weather this is common knowledge or if it has been posted before or even if what I did was right but
it worked for me and saved me $500 from upgrading. I've got copies of the two files if anybody needs them.
j2d2graphics
I could use them
I could use the files if you have them still. Also does anyone know if Rasterlink 3 will run a jv3 160 sp
Hi everyone
port" or something.
C:\RstrLink\Hot\
oggy
I've uploaded the two files, I had to change them to txt so they would upload. You need to rename the extension as .dll
Best of luck, let me know how you get on.
  • RlpMon.txt
  • RlpMonUi.txt
clstore
I download the files and i copy them to C:\RstrLink\Hot\ (first i changed the extensions to .dll) and it still dosen't work ... same error ...
I have the latest ver mkdriver_340 ....
i don't know what ealse i can do ... to make it work ...
my OS is win7 x64
and my machine is mimaki jv33-160
judsonsigns
Printer Problems
I am having the same issue with Windows 7 X64, Printer CJV30 - 130, any ideas?
my OS is win7 x64
clstore
I don't know what to say ... on windows xp x32 works fine ... i'm haveing this problem only with win 7 x64 ...
if someone has a solution please reply
bentotdagr3at
Sorry to revive this post but I'm having the same problem. I'm trying to run Rasterlink 4 and I'm getting the same error mmk rlp port error.
Help
