How to install laminated window perf vinyl on the storefront?
phototec
Is it better to install laminated window perf vinyl on a storefront, wet or dry application?
Stacey K
I like making signs
DRY!!!!!! DO NO APPLY WET!!!!
Window perf is easy to apply if it's laminated. Many of us on here enjoy applying window perf. If you apply it wet the moisture will never dry out, you will have an absolute mess. The other thing to keep in mind is that after you apply it you are going to see squeegee streaks - no fear, as the vinyl sets the streaks will go away and the surface will be nice and smooth.
phototec
Ok, the window perf is laminated, with Oracal 290F, do you use application tape to apply or go without application tape? Thanks
phototec
Stacey, the window perf is laminated, with Oracal 290F, do you use application tape to apply or go without application tape? Thanks
BetaCtz
What's the group consensus on paneling perf?
Slight overlap from panel to panel, or butted and then "edge taped" on a seam?
Original poster - don't forget to use edge tape around the perimiter of your graphic (clear or black cast 1/2" pinline tape).
This will make your install last much longer. Perf films tend to not last as long as regular films.
tulsagraphics
A bit of both. Overlap during install, but then cut through the middle of the overlap.. removing the excess from both pieces... which gives you a tight butt seam. Seal all edges and seams like normal.
Boudica
Tex, you didn't push it into the edges and trim it... looks like you had some trimming to do at the bottom.
gnubler
Let me know if you like it. I bought mine based on Tex's recommendation but have never gotten the hang of it so I'm back to regular squeegees.
