How to Process this Image for the FX?
stitchup
I know for may, this is pretty basic stuff but, as I've been away from my Gerber FX for a long while and when I do use it, I'm printing spot colour labels, I'm stuck :oops:
I've been asked to produce some stickers for the rear end of motorhomes.
This is the image I've been sent.
It's the gradation from yellow to white in the cheeks that I have trouble with!
I've tried importing the jpeg into Composer 3 but instantly the picture loses it's vibrancy - I'm obviously doing someting wrong!
Would some kind soul help me with step by step instructions :D ?
My customer wants 150 of these at 25cms diameter.
Many thanks
John
CanuckSigns
Sorry I can't help, but I would be interested to know as well, we use our edge for a lot of solid spot colour printing and things like this would be done on our versacamm, but if I knew how to print simple things like this on the edge it would open up alot more opportunities!
edgette
Why not just redraw it? I wouldn't think it would take more than 15 minutes and you can get the colors to pop how you want.
Fred Weiss
  • Draw the elements of the image with your shapes tool and Bezier pen. including a hidden circle that is filled with Spot Yellow.
  • Set the fills to Spot Black and Spot Yellow. Set all Black fills to Overprint and compound them.
  • Draw a circle on each cheek to correspond to the outside of the gradient.
  • Set a radial gradient fill in each with a Spot Yellow fill running from 100% to 0%. Compound the gradient to the outer Spot Yellow circle.
royster13
I am curious why you want to print them on your FX....What would your costs be doing them in-house versus outsourcing...
CanuckSigns
for 150 pcs, we would also look into printing these in house. I'm guessing you are looking at 2 hours start to finish. if there were more than 1000 of them, we would look into outsourcing.
royster13
But i am still thinking outsourcing will be less than the sum of the parts....2 hours has to be at least 180.00 and I can buy them finished for less than that..
stitchup
Thanks for the help Fred, much appreciated.
To be honest, I hadn't thought of out-sourcing. However, I should be able to do these simple tasks.
Thanks again.
John
