HP 25500 Cutter Adjustment
CreatedDesigns
Is there any way to adjust the cutter on the L25500 printer?
It recently started not cutting all the way through the 3M IJ180C-V3. It cuts the backing paper but not all of the vinyl. a quick tug and it comes loose. 55-110 for drying and cure temps. was thinking it was the heat causing I to form around the knife and not cut.
Also where can I get a replacement knife If need be? Well off to Google......
Don
