HP L25500 printer
robsonr
Hi everybody,
I am new to this business and I appreciate any feedback. I got an offer to buy HP L25500 printer. I would like to know, considering that it is a used printer, what I should be looking out for and checking in terms of potential problems. Which parts are costly on this printer and very likely to be worn out (the age of the printer is 4 years).
I would also appreciate feedback on a latex printer technology as such. Would you recommend it over eco solvent?
Thank you in advance for your feedback.
KevSign
Check belt - print head - total square feet if too much depend on the price.
Advantage than Eco-Solvent low maintenance, some services you can fix, no banding most print
Dis-advantage depend your market some medias not friendly to print.
But our shop all HP Latex!
robsonr
Thank you for the prompt reply.
When you say check belt, what exactly I need to check on the belt?
dale911
President
check internal server
When the machine is setup and powered up, you should be able to log in to the internal server of the printer with the IP address. It will tell you how much substrate has been through it and how much of the 3 service kits have been used. Kit 3 is about $800 or so from what I have been told, but it takes a long time to use it up I bought my machine with 20k feet through it and put another 10k through it and the kit is only at 13% used.
