Identify Installation Hardware
LoGl
Hey all,
I am looking for a particular piece of hardware and am just not sure if these were custom made. I can get them made...but was hoping not to have to reinvent the wheel. As you can see in my photos, the track/ channel that was used, I'm told is Unistrut. After searching through images and Unitstrut website...I'm not finding the clamp that was used. I have more images of the clamp, but I think you get the basic idea here. It inserts into the track, slide up and grasps on to an I-beam (one on either side of beam). Works like a charm.
Anyone have and idea where I might find these?
Thanks much....Lori
James Burke
It appears to be a machined extrusion...meaning that it's most likely a stock item somewhere.
Had it been totally machined from billet stock, then it would have been a custom.
JB
Typestries
Check your local electrical supply house......or mcmaster carr.
Google image "beam clamp strut" there are a bunch of varieties
Moze
Pretty sure it's a rocker from an LS1.:Big Laugh
JK...
There are lots of I beam clamps from the various maunufactures...maybe replace that with one that's easier to find...?
MikePro
does the "replacement" need to be so beefy?
depending on what you're mounting, it doesn't look anything different than what you can get out of a toggle-bolt/beam-clamp.
LoGl
Thank you all who have helped me out here. I will continue searching through the different sources you have identified. At the end of the day do the clamps need to be precisely these type...no. But I am adding to a sign post that has existing signs on it and if I can easily find the same type...it just made sense. If not...I will find a way to make installation work. These clamps worked easily and perfectly so hoping to find and use them. If I do find...i will post my source.
It never ceases to amaze me how helpful fellow sing folks are. I thank you whole heartedly.
Lori
LoGl
JK...
Here you go....yes...could be that I am supposed to be working on an engine...lol
But seriously....a couple of you made great suggestions...in the end, I think McMaster Carr is what I will go with....similar use product, not the beefiest clamp, but the weight load is fine to use something smaller.
have a great day all...
