Just for giggles
Flubber
Customer loves it. But i want an opinion from you guys. Dnt hold back... I personally Dnt like the white but that's what they wanted bc it matches all the banners that was done previously.
Flubber
And i know that (White Zinfandel isnt centered correctly in this pic but the proof is :banghead:
bob
The LHF Boston Truckstyle is locked in a death struggle with the LHF Orchard. Thou shalt not use two specimen type faces in proximity to each other. Especially when they are as incompatible as these two.
That and soften the cowboy hat just a taste.
Flubber
How about this?
I would drop the hat down a bit over the top of White Zinfandel and then make the copy at the top larger and divide it into two lines something like this...
Sammy Taylor
Memorial Scholarship
...so it's larger and reads better.
xxaxx
Bob is right ... the hat is really distracting ... If using PShop, I would suggest adjusting the background image a bit so that there is a bit more texture directly under the hat and then guassian blurring the hat a touch to soften the edge and then switch the blending mode on the hat to something like multiply or overlay so that the background texture shows through and grunges up the hat a bit. That will help give the hat a look like it was printed on the really old paper background and should make it less distracting. Also when I do that with a grungy background like that I like to also add in an outer glow of black set to multiply with the noise value turned up a little bit and then play with the opacity of the glow ... it usually adds a nice little extra detail.
xxaxx
Sorry for the double post, but here is a quick example I threw together for you so you can visualize what I was trying to explain. I set the hat to overlay, its a bit hard to see the detail when its this small, but at full size you can see all the grain and grunge from the paper background showing through on the hat, which gives it some good variance in color tones as well.
TwoNine
Honestly - The text on the back is killin it for me - But here's just an idea for the text and the hat in front.
Love it/Hate it.....Same price....Free.99!
-Chad
EDIT : LoL....Forgot the 's' in scholarship. Whoops! Ehhh.....
