bigben
I'm making acrylic signs using my laser. Right now, I'm using VHB tape but I'm looking for something I could install on the sheet of acrylic and cut everything with the laser. It will be mostly for small sign like 6inX6in but it could be 1/2 thick acrylic sometime. If I could use this same material and technique for larger piece for interior signs (mostly stick on painted drywall) it would be a must. I was looking at 3M 9502 or orabond 1375 since they are making 24in roll. I'm looking for 12in, 24in and 48in wide roll. I have a roll ok drytac multitac that was laying around and work well for the test I made so far.
That is the industry standard about this and/or what is your recommendation?
Thank you.
Thank you.
