Lighting from ground ?
laserfred
Hi guys,
I am looking for tips on selecting lamps for illuminating a 6' (wide) x 4' (tall) sign that will be installed just above ground. It's for a condo building. I would install the lamps on the ground, just in front of it. Where to get these ? what is the appropriate power needed ? can a single lamp per side do the job ?
thanks!
signage
Make sure this is allowed by code! Most places are starting to snuff this type of lighting out!
Moze
Precision Sign Services
I'm not sure where you would get them in Canada...surely there are lighting suppliers/wholesalers up there?
LightAll is a company here in Dallas that is really good to deal with.
Ask for Bryan if you call...
Light All, Inc
2837 Anode Lane
Dallas, TX 75220
(214) 358-5331
Billct2
First be sure they're allowed.
Then hire an electrician to select and install the lamps. You can save some money by doing the prep work, trenching etc.
Third if at all possible talk them into lighting it with goosenecks
or something on the sign itself. Ground lamps just never seem to last.
+1
  • Ground lights don't work when covered with snow.
  • people hate trimming grass around them.
  • Kids can really mess with them.
  • All light looks much better when defused from the top down rather than up.
laserfred
Thanks everyone for the help. I finally found a local lighting supplier for the lamps. Nothing fancy, PAR 38 bulbs and sealed sockets, cast aluminium and picket. The heat from the lamps melts the snow in winter so no need to dig around.
Cheers
Billct2
Let's see a pic what it looks like next February, I hear you get a bit of snow up there.
laserfred
Snow? I'm not sure I know what you're talking about...
