Logo Carpet maniacs
WildWestDesigns
Also, I assume the rug comes white and you sublimate the ink on it. Is that how it works? or are you sublimating onto a black rug.
It's white. You can't dye anything on totally black substrate with sublimation. Only way is if a black rug had a white panel to sublimate (such as the case with black mugs, but there are issues with those as well).
WildWestDesigns
Black can turn out really well using sublimation inks, but it depends on the substrate and the profile. Type of printer can also affect how it lays and even the individual printer might actually lay a little more ink then another.
TXFB.INS
Please PM the price as well,
what machines did you finally end up getting?
On shirts how do you work the designs onto a black shirt since dye submission is best on white/light
WildWestDesigns
I would actually use white poly embroidery thread and sublimate that on the darker substrates. Gives it an embroidered look, but you don't have to do the complicated digitizing if it was all embroidery. Plus you are able to use cotton and blends instead of just pure poly due to the fact that you are only sublimating on the pure poly embroidery thread.
Other then that, you would have to sublimate the white shirt black around the design. If you use this method, I would suggest using a shirt that you have to sew up afterward. Otherwise, the armpits will be an issue with getting sublimated at the very least.
I don't know of a black poly shirt that would have a white space for a sublimated design (at least the white space positioned logically for this application) like you have on black coffee mugs with the white band around them to sublimate.
JoshLoring
White is the base for everything, if someone wants a black shirt I'll dye it all black, or just silkscreen xfer it. Easy fix. Having a huge press helps make things easier and cleaner.
Had a bunch of wraps today but still played a bit.
OlsonSigns601
Very nice.
Did you get a new healing mat? looks shiney like the day we got ours.
J
john1
Guest
I hope to one day have a nice shop like yours Josh, Great work as always
JoshLoring
I hope to have one someday too! Our office area is nice.. The shop.. Could use some work! Lol
Those look great. What printer are you using?
Mutoh from Advanced Color Solutiions.
More fun..
I saw an old Allbright shirt and liked the style. Threw this together real quick.
JoshLoring
Tried some all over designs printed inside out so they looked worn and vintage. I think I like this type of application the most.
