Need Help MIMAKI CJV 150-160 System Halt
JakubDratva
Hey guys,
Does anyone have a problem with this message in Mimaki CJV 150-160?
System Halt (1)
1b4:pCB SLDR2H-F2
It appears during the start.
Thank you for any ideas about what could case this problem.
It means fuse 2 on the slider board is blown. Check the cables that plug into the slider for burns and replace or reinstall any that are damaged or improperly installed. Then replace the fuse.
VegasPrinter
I got the exact same error, today, changed the printhead and plugged everything back up then i got (system halt (1) 1b4:pcb sldr 2h-f2). One of the cables seems to be worn out. Do you think that's what is giving me the error?
PJ758
Has anyone got this error or know what it means
It means the printer isn't seeing the slider board. Either it's unplugged, the slider board is damaged, the trailing cables are damaged, or the main board. I would double check you have the trailing cables plugged in correctly on the slider board to start. Check for damage.
PJ758
yes everything is intact, error occurred after a powered fluctuation.
JDC
Hey guys,
System Halt (1)
1b4:pCB SLDR2H-F2
Did you solve the problem's
