Need Help MUTOH ULTIMA 1400D STUCK!!!
We currently have a Mutoh Ultima that we've been trying to get working. As i was installing the firmware update, the computer hit an error n stopped. Unfortunately, the machine is stuck on the initialize screen, and the computer is telling me to change the baud rate on the cutter, but I am unable to due to the screen being stuck. Does anyone know a work around this, or a way to get the firmware on the machine.
Umca
I think you can try to update with PCMCIA flash card. It is hardware option with direct access to plotter's memory.
Umca
Hold on....
File *.bin for update with PC and file for update with flachcard are different. For flashcard you have to use *.pcc file.
Another option - update with COM port cable by attached manual for critical situation.
Umca I read that in the manual, but that’s for situations outside the critical areas correct? My issue occurred inside the critical area, that’s why I am assuming that I need to update with the flashcard. Are you aware if the *.pcc file is downloadable from the Mutoh FTP? Thank you and your help is greatly appreciated.
