My company website, what do you guys think?
Speedsterbeast
As most people when requested to rate something, we tend to look for the negative. With that in mind. I don't much care for the fact that all of your shirt demo pictures are two coloured, yet all of the pricing on the same pages list for one colour
spectracolor
I would be surprised if they used a template. They are a top award winning web design company.
Here. I did a screen capture...It looks like they are using WORDPRESS to me...
Supergirl
One of your plugins also has debugging turned on.
this is all in the console
Consider using 'dppx' units instead of 'dpi', as in CSS 'dpi' means dots-per-CSS-inch, not dots-per-physical-inch, so does not correspond to the actual 'dpi' of a screen. In media query expression: (-webkit-min-device-pixel-ratio: 2), (min-resolution: 192dpi) (index):50
Consider using 'dppx' units instead of 'dpi', as in CSS 'dpi' means dots-per-CSS-inch, not dots-per-physical-inch, so does not correspond to the actual 'dpi' of a screen. In media query expression: not all, not all, only screen and (-webkit-min-device-pixel-ratio: 1.5), not all, only screen and (min-resolution: 120dpi) (index):58
[cycle2] --c2 init-- jquery.cycle2.min.js?ver=2.1.2:6
[cycle2] loader: true (boolean) jquery.cycle2.min.js?ver=2.1.2:6
[cycle2] overlayFxIn: fadeIn (string) jquery.cycle2.min.js?ver=2.1.2:6
[cycle2] overlayFxOut: fadeOut (string) jquery.cycle2.min.js?ver=2.1.2:6
[cycle2] overlay: #cycle-widget-skin-overlay-356 (string) jquery.cycle2.min.js?ver=2.1.2:6
[cycle2] captionFxIn: fadeIn (string) jquery.cycle2.min.js?ver=2.1.2:6
[cycle2] captionFxOut: fadeOut (string) jquery.cycle2.min.js?ver=2.1.2:6
[cycle2] captionPlugin: caption2 (string) jquery.cycle2.min.js?ver=2.1.2:6
[cycle2] captionTemplate: {{name}} (string) jquery.cycle2.min.js?ver=2.1.2:6
[cycle2] caption: #cycle-widget-skin-caption-356 (string) jquery.cycle2.min.js?ver=2.1.2:6
[cycle2] centerHorz: true (boolean) jquery.cycle2.min.js?ver=2.1.2:6
[cycle2] autoHeight: false (boolean) jquery.cycle2.min.js?ver=2.1.2:6
[cycle2] centerVert: true (boolean) jquery.cycle2.min.js?ver=2.1.2:6
[cycle2] pager: > .cycle-pager-container .cycle-pager-inside .cycle-pager (string) jquery.cycle2.min.js?ver=2.1.2:6
[cycle2] next: > .a3-cycle-controls .cycle-next (string) jquery.cycle2.min.js?ver=2.1.2:6
[cycle2] prev: > .a3-cycle-controls .cycle-prev (string) jquery.cycle2.min.js?ver=2.1.2:6
[cycle2] swipe: true (boolean) jquery.cycle2.min.js?ver=2.1.2:6
[cycle2] delay: 1000 (number) jquery.cycle2.min.js?ver=2.1.2:6
[cycle2] speed: 2000 (number) jquery.cycle2.min.js?ver=2.1.2:6
[cycle2] timeout: 4000 (number) jquery.cycle2.min.js?ver=2.1.2:6
[cycle2] paused: true (boolean) jquery.cycle2.min.js?ver=2.1.2:6
[cycle2] fx: fade (string) jquery.cycle2.min.js?ver=2.1.2:6
[cycle2] [0] desc: <a class="cycle-product-linked" href="http://www.spectracoloronline.com/shop/online-shop/aprons/">View this Product</a> (string) jquery.cycle2.min.js?ver=2.1.2:6
[cycle2] [1] desc: <a class="cycle-product-linked" href="http://www.spectracoloronline.com/shop/online-shop/basketball-goal/">View this Product</a> (string) jquery.cycle2.min.js?ver=2.1.2:6
[cycle2] [2] desc: <a class="cycle-product-linked" href="http://www.spectracoloronline.com/shop/online-shop/checkbook-wallet/">View this Product</a> (string) jquery.cycle2.min.js?ver=2.1.2:6
[cycle2] [3] desc: <a class="cycle-product-linked" href="http://www.spectracoloronline.com/shop/online-shop/custom-iphone-cases/">View this Product</a> (string) jquery.cycle2.min.js?ver=2.1.2:6
[cycle2] [4] desc: <a class="cycle-product-linked" href="http://www.spectracoloronline.com/shop/online-shop/iphone-5-case/">View this Product</a> (string) jquery.cycle2.min.js?ver=2.1.2:6
[cycle2] [5] desc: <a class="cycle-product-linked" href="http://www.spectracoloronline.com/shop/car-accessories/license-plate-frame-chrome/">View this Product</a> (string) jquery.cycle2.min.js?ver=2.1.2:6
event.returnValue is deprecated. Please use the standard event.preventDefault() instead. www-embed-player-vflXHU025.js:28
Anyway, yeah, like it was said before, it's not really appealing.
it would be if you offered signs and t-shirts, but not web design. so, if you're a sign shop, nobody expects you to be a web designer OR a web developer.
if you still decide to stick with it, add some padding to your forms. the input fields and captions are right against "the wall"
yeah, i'd look for a different template.
and i guess i should probably stick to development and stay away from signs LOL
spectracolor
You don't have to buy a template to build a website with wordpress...
I thought theme you use determines the overall look & basic structure of your website. What they used doesn't look like a "free theme"...If they were able to do that without buying any theme and did that from a scratch...WOW!!! That is insanely AWESOME!:thumb:
Whether they did that from a scratch using the free theme or premium theme, you still have to use a some kind of theme to use wordpress, I thought...
spectracolor
Thank you for the tip on the padding on the forms.
However, I lost you when you said debugging thingee....Which plug in do you think it is and what's the effect of it? (I obviously don't know this far :) )
Thanks in advance~!
player
Dan and his crew are world class top of the game web designers.
They would design Wordpress from scratch.
