Question Never Used This Before............................
We're doing a truck at the moment and have decided using 3M 1080 non-visible air release might be the way to go for some of the lettering areas because of all the rivets. This is really meant for ColorChange projects, but we'd like to cut letters out of it. Will it cut the letters and not chew the corners while twisting and turning ?? The letters are all about 17" tall and just block style. No fanciness to them. The phone number is about 6" tall.
Any ideas if this will cut well ?? My best pricing is on the 3M over Oracal or Avery.
:thankyou: Gino
ThatGuy
3M 1080 works great for this. Here is 1 example.
ExecuPrintGS
works great, just do a few cut tests before sending the whole job. Pressure settings will be a little different compared to regular cast vinyls.
Dennis422
Avery 900 RS EZ would be another option.
Air release, repositionable and I believe cheaper than a color change films.
gabagoo
It works well, the only thing I dont like about using it is that the premask does not really stick well to the liner and can curl, so be careful how you store it before application..or staple the corners
jfiscus
Rap Master
3M solid colors are in 180MC (instead of 180c) now, is it a color that is not available in that series? The 1080 is a bit thicker than 180, so it will be a bit more of a hassle over rivets, etc, but does a better job at being a "block out" material.
pjfmeister
We cut some large script out of the Oracal 970RA version of color change today and it worked great. Turned the speed down and the pressure up and it cut and weeded better than I anticipated.
d fleming
Have a job tomorrow using 180c gold metallic for cut letters. Repeat customer, medium sized fleet of heavy equipment. Stuff does great.
tdupster
:thankyou: Gino
All by using 3M 1080 gloss black, and the amount of time just weeding the product was a pain in the.... Lol. But definitely great vinyl to work with
Sent from my LG-H831 using Tapatalk
d fleming
Yes, weeding and taping it are a pita but it lays and stays great.
Wanted to give an update. The 1080 worked perfectly for us. It cut swimmingly, weeded without any problems and went down with application tape and we put each and every rivet down without any hassles.
Thanks for all the help. :thumb:
Johnny Best
Like you always say: "We like happy endings".
