New Mimaki coming to Print 17, UVLED roll-roll
Steve Weist
Mimaki UV Flatbed Specialist
New Mimaki UCJV300-160 roll-roll with cutter and LED curing will allow you to print day / night morphing images that will enable you to reap much higher margins. LED cured roll- roll is HERE!!
If you are coming to Print 17 or would like to get a live demo please contact me asap.
Steve Weist
615-812-3001
www.pdsequipment.com
See here ?
ucjv300_web-1500x500-gif-gif.130145
BigfishDM
What print heads does this model have?
How many heads does it have?
Technical overview of the Mimaki UCJV300-160 Cut-and-Print Device
Print System On-demand piezo, 2 print heads, 8 color channels
Maximum Print Width 63.38 inches (1610 mm)
Print Resolutions 300, 600, 900, 1200 dpi
Maximum Print Speed Up to 277.7 SqFt/Hr (25.8 SqM/Hr)
Ink Type Mimaki LUS-170/LUS-175 UV ink: C, M, Y, K, Lc, Lm & W
Ink Capacity 1 liter bottles
Maximum Media Thickness Up to 0.04″ (1 mm)
Maximum Media Width 63.77 inches (1620 mm)
Maximum Roll Weight 88 lbs. (40 kg)
Operational Environment Temp: 68.86˚ – 86˚ F (20˚ – 30˚ C)
35-65% RH (non-condensing)
Connectivity Ethernet, USB
Power supply AC100V~240V x2
Dimensions (W x D x H) 114.12” x 30.5” x 58.1” (3305 mm x 750 mm x 1180 mm)
Weight 414 lbs. (188 kg)
Catherineeee
would you know the PH name? thanks..
