ONYX Thrive Trial - OPOS CAM Barcode Not Printing | Trying to Set Up OPOS XY2 Workflow
NITOS
Hello,
I am trying an ONYX Thrive Trial, *which completely bricked my access to Onyx Gamaprint btw* and I am trying to set up my Barcode workflow to Utilize XY2.
Backstory, I am going through options on trying to fix an accuracy problem, and my next path is trying to utilize the XY2 workflow, but I am now encountering this issue.
Check this link to catch up: https://www.signs101.com/threads/su...-at-the-end-of-job.175261/page-2#post-1632200
I followed this video:
I followed the directions step by step, but for some reason, it is printing without the Barcode. I have never had this problem before, yet I have been working on ONYX 19 for the past 3 years, so upgrading and trying Thrive, there is a some new things that I am not aware of that I may be missing.
The Trial is 22.5.1, and my Summa software and firmware is up to date, I cant figure out why the barcode isn't printing.
I am also trying to get the OPOS XY2 workflow to operate and read the back bar, but I didn't see it do it. *This is me manually loading the cut file, without the barcode, It may change once I fix the barcode issue* If anyone has instructions to getting OPOX XY2 to operate as intended that would be awesome also!
Any ideas?
NITOS
It looks like I was able to get a barcode to print via Summa, and OPOS X option, but I dont understand why it wont print through the OPOS option, the directions are specifically for "Summa S2TC OPOS CAM Cutters"
Graphic Extremes
Knows To Little
try the OPOS XY2 setting, you image shows OPOS X, I just checked mine and I use the OPOS XY2 and the barcode shows up. Let me know if you need more help
Graphic Extremes
Knows To Little
you also have to select your cutter in the job editor, hit apply and the print and then submit
balstestrat
Problem Solver
Guys it's also different based on Onyx versions. Onyx likes to keep changing things and on the video they only showed two versions from over a year ago..
