Need Help Please Help! I need service manual for my Roland Soljet Pro II Sj-540
delriosigns
Hi Everyone. Hopefully someone can PLEASE help me out. I have been looking everywhere and I can’t find the SERVICE manual for my Roland SJ-540. I even found a couple websites that seemed like they had the pdf for sale, but after paying there is no link and can’t get a hold of their customer service. Most likely a scam I know, but I’m desperate. I had a couple nozzles/nipples break on a couple of my printhead manifolds. I just purchased new manifolds but want to make sure they are replaced correctly and don’t want to spend a fortune paying a tech. Please help!
Signturesigns
hey im having the same problem did you resolve it? woud love to chat on a call whats your number? mine is 727 641 7115 lets knowledge share please!
Broome Signs
Hi Replacing the head cap is a very simple process
Turn the printer off and unplug it
Lower the docking station manually, there is a hole underneath the printer to access the worm screw
Remove the print ribbon cabal
Remove the spring from the top of the head carriage
Take out the 3x screws holding the head in
Pull the head towards you and up
Once out remove the manifolds x2 screws
Replace manifold and put the head back in the printer
Replace the damper
Turn on the printer and perform a couple of powerful cleans
Then print test print
(Try to line it up as is came out, you may have to adjust the bi directional settings if the print is out)
Sheila Case
Having some issues getting this printer up and running. Roland Soljet Pro 2 SC-540 We bought it without the heads. It had been sitting, without heads for about a year before we purchased it. We replaced the heads, caps, dampers, all 3 pumps and lines from caps to pumps. I was able to draw ink into the dampers but none at all past that point. Tried drawing though waste tube coming out of the pump, nothing. Drew through lines between cap tops and pumps, nothing. Cap tops are still dry. Tested head board fuse and found that F2 and F4 are ok but F3 is blown. I did notice that the F2 & F3 are 72V 3.15A and F4 is 63V 3.15A , does that make a difference? It looks as if these may have been replaced prior to us buying the printer (see pic) I have ordered new fuses to (all SOC 72V T3.15A, which is what the service manual specifies). How would I also test the transistor and where on the head board will that be located? (I have also ordered new ones, just in case).
No errors after powering up (other than it's time for a wiper change, which I did but still get the "time for wiper change" error). I am able to do cleaning cycle, go through service menu, test print, everything but doesn't print anything on test print, just goes through the motions.
Service tech wants $400 min. to come to me to check it out (partly because of the area of Texas I am in), so I am determined to get this thing going myself if at all possible. Any suggestions would be most appreciated!
Broome Signs
If you have any red led lights on the head board are read you will need a new one
If all the led lights are on the board are green
Power down the printer
take all the heads out
Put a small amount of tissue in a flat dish and pour some cleaning flush into the dish just too wet the tissue
Put the heads on top of the tissue
Add some more cleaning flush to the dish , just to the point where the silver cap on the head is coverd
Do not get any flush on the top board or into the print ribbon slot (very bad)
Cover the dish
When you see the flush level go down the heads will be drawing the flush into themselves 24 /48 hours
Take all the ink out and replace with flush cartridges
Reassemble the heads into the print carriage
Turn the printer on in service mode
Perform power fill
test print on paper
Once the heads are firering change the flush cartridges for new ink
Perform powerful clean until all the dampers are full of ink and then 2x more power clean
X1 med clean x2 normal clean
Now try the test print
