Nick Ng
Hi Everyone, I have an Epson S50675 printer.
I did some fuse testing with a multi-meter earlier to see if I have any blown fuse or bad print head cable. Here is what happened:
- Fuse (F9) for head #2 is not responding to the multimeter, but ribbon cable from the main board does have a normal resistant for head #2.
Here is the result from the latest Nozzle Check which is completely different than the nozzle check I did 2 weeks ago. At this point should I replace the Fuse (F12) for head #2 to solve this issue?
Thank you!
Thank you!
