Question Random Black Lines
Brit
Random Black Lines appeared right at the end of a 2500 mm print
it was the 2nd of two the only thing i changed is I made this one 1cm bigger in Versaworks the rest of the print is G8
I was feeling so good after changing one of the heads and getting it this far with lots of help from this forum and you tube but now its the nxt thing gone wrong
Gotta end one day hasn't it fed up to say the least
euronymous
Which direction are they going? Are these vertical (printing up and down as the media feeds out) or horizontal (printing in direction of carriage movement)?
euronymous
Start with cleaning your encoder strip with some alcohol. If this doesn't help you may have a print carriage cable that is damaged.
