Rasterlink
ECVSoares
Hi, I have a mimaki CJV-30, and I used Rasterlink... The prints started to come out bigger than the original files, for example: a job with 3000mm comes out with 3030mm...
Does anyone know what to do to fix it?
DL Signs
Never go against the family
Is it in the feed direction? Run the feed compensation in the setup menu, it'll print a test pattern, change the values till it's correct. Instructions are in the user manual under Media Correction.
ECVSoares
It is in length not in width, 1 piece with 2000mm feed comes out with 2020mm.
DL Signs
Length is what the feed compensation adjusts. It only takes a few minutes to run the test print and adjust.
ECVSoares
Yes, I understand, I haven't adjusted it for some time, the 2 lines cannot be superimposed, I'll adjust it and see if it solves the problem, if not I'll reinstall the rasterlink. TKS
