First of all hi to all Sign 101 members. I am new member of this forum.
My name is Andrej and I am from Slovenia.I run small business of making wall decals, car decals, glass decor, etc... Till now I was cutting with Roland grx-450AG. Yes with this cheap and great machine I was cutting for about 2,5 years.
I need some help and advice.
I just buy Roland cj-500 converted to sj-500. Plotter was not operating for about 6 months. Like it seen it was very good clean out before they stop using it. Refill cartridges are clean, tubes too and the heads? I dont know![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Yesterday I was try to cut with it. It cut prfect!
But...I don't know how to setup material length. If I put in material in length of 126cm I can cut only on about 110cm if is image bigger it say that media is too small. Is this normal or I can adjust to cut on about 122 cm length? And how can I adjust the cutting length?
I got problems with sheet cut. If I holding down the sheet cut key for 1 second it start to go left and on the very left position mechanism drops blade just for second,but the blade immediately return in up position and the head returns to start position on right. It doesnt cut. Have anyone idea what can I do to make it work?
And for last I need some advice how to make it print![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
I don't know anything about printing. I don't even know how to remove heads, how to clean it...
So I will be very glad if someone can email to me service manual for this model. I try to find it on web but without luck. So please if someone have it if you can send it to me.
My email: andrej.unuk@triera.net
For now I buy refill cartridges, pump(I think this is piece with gears) and I am waiting for colors, drain bottle, and tubes.
I didn't order heads for now because I hope that heads in plotter are ok, I will try to clean it. And again I need advise how to clean heads, what I need and how to do it?
I see just below the heads when they are in start position, two small sponges, they are hard because of dry ink, how can I replace this sponges? Are this some special sponges or I can use any sponge?
I someone have any advice what and how, I have to do to make this plotter print, please help me.
Br Andrej
Br Andrej
