roland gx-24
AVL Signs
downloaded latest update from sai flexi, since then the orientation on the cutter is messed up, always cuts straight even if I change it to cutting sideways...…..spoke with sai they said its the cutter not the software any one that can help please?
MikePatterson
Head bathroom cleaner.
Did you try and rotate the cutter orientation on the cutter itself? Sai is weird sometimes. My GX640 cuts 90 degrees out from my smaller rolands. I called them and got the "we get the settings for the driver from the MFG". Funny thing is before I upgraded to the cloud and was running FS8.6 I had to make my own driver that ran the cutter fine in the proper orientation. With the new Flexi, I cant even find the csm files to edit.
netsol
does the gx24 have a setting that toggles, like some of the hp's
software settings supercede plotter
plotter settings supercede software
perhaps the software update "broke" that setting?
