Roland sp 300-v
j0el1212
You are not pulling ink through the M/Y head. That is the first issue that must be solved. There are several adjustment to be made to insure the capping is correct. Do you have a service manual?
Those are the fuses. Measure them with a resistance meter on it's most sensitive scale. They should read zero. If either of them reads open, that indicates either a damaged or incorrectly inserted ribbon, a shorted transistor on the main board or a bad print head.
Where are you located in Florida?
Yes I’m in Florida. Yes I do have the manual. I did switch the cap top idk what else to try.
j0el1212
So here’s the latest. I put the Blk and blue dampers in the magenta and yellow print head and the magenta and yellow dampers in the Blk and blue print head nothing came out in the test print of the magenta and yellow but the black and blue came out perfect. So is it safe to say it isn’t the fuse it can’t be the cap top or the print head or ribbons. Even tho the Magenta and yellow dampers are new I have a feeling that’s the only thing that makes senses. Any other ideas?
Should I just buy knew dampers again and where can I find reliable one?
Jim Hancock
Old School Technician
Please post a pic of the caps after you did the above. When you do this damper swap, you must do at the very least a medium cleaning to flush the previous ink colors out of the head. You will see a change in the color of the inside of the caps, where the K/C left cap is looking M/Y and the M/Y right cap is now K/C. It is very important to post the cap pic for a true assessment if the damper swap was done correctly and the caps are doing their job. This pic will determine the next step.
j0el1212
Jim Hancock
OK, you are not pulling ink through the M/Y head yet. If you were, you would see the color change I described. Also, the M/Y cap looks dry, while the K/C cap is wet. So this is the first thing you must fix. Any other steps are a waste of time until you know you have ink going through the head. Let me gather up the necessary procedures and tests to move forward. I will reply in detail in the morning.
Jim Hancock
These are the steps that need to be taken next:
1. "Intialize the limit". After doing this step, go into service mode and do a test print. Ignore the test print results, but instead check the cap to head alignment. Do this so you can see where the machine parks the head through the normal operation. If the alignment is off, note which way and how much. To adjust this, move the print carriage out of the way and do steps 7-10 in the "Initialize the limit" document. Run the "Intialize the limit", restart in service mode , do a test print and observe the cap/head alignment. Once the alignment is perfect, do the cap height adjustment.
2. Do a power clean, observing the clear line coming from the M/Y cap, watching for ink coming through that line. If you are still not getting ink through that line, disconnect it at the Y fitting, put a syringe on the line and pull gently. If you are pulling air or ink with air bubbles, then I suggest you replace the cap with an Roland OEM cap. Using aftermarket caps are like rolling the dice, with a good chance of getting a poorly manufactured one.
Please post the results and I will advise the next step.
  • SP-300 Initialize the limit.pdf
  • SP-300 cap height adjustment.pdf
j0el1212
Finally got a the Roland OEM cap top and install it same results. Now I’m doing the limit initialize. Wish me luck.
j0el1212
Just Fisnhed the limit initialize and it seems to all go smoothly but still no magenta or yellow and everything seems to line up perfect.
j0el1212
411CD80D-58F4-4A35-991A-E7C19E17E3DE.jpeg Trying to do the Height adjustment me and keep getting this message service mode protected once I try to start it.
