Roland Sp-300v Tech Question
Sign Works
Cannot find this info anywhere. When manually raising the captops, how far up do you raise them? I recall reading somewhere to go 1-2 full turns past the point where the captops come in contact with the printheads. Is that correct? Is there any standard for this adjustment?
equippaint
In case no one responds that really knows, we just snug it up. I dont think its overly critical. Done it many times with no ill effects.
Joe House
Sign Equipment Technician
If the printer doesn't work, raise it till the compression stops. If it does work, it doesn't matter. Just raise it till it touches, them turn on the printer and let it reset itself by doing a cleaning as it powers up.
Sent from my SM-G935V using Tapatalk
