Rotate nested job in production manager
Mata
Is there a way of rotating a job once printed and sent to the cutter?
Basically, I've printed a nested job fine, I've cut it off the printer and there's not enough at the end of the print for the cutter. If I can rotate it 180 degrees it will work fine. I just can't work out how to rotate it other than if I rip it again.
MikePro
I've taped-on tails plenty of times
Other times, i'll just deselect portions of my print&cut, to only cut the front-end first before rotating my page and outputting the remainder of my cuts.
