Goatshaver
So I've noticed when I laminate single sheets I get a horrible shift in cutting. I'm only assuming this is due to how I'm laminating them, if I did this on a roll it wouldn't be an issue. I'm just not sure where I'm going wrong with setting the sheets up to run through the laminator. The only thing I can think of is that it's because I'm not winding the sheets up on the take up roll, but I can't see why that would change it. I'm scatching my head on this one.
As you can see from the image one sticker is from the bottom on the sheet and the one on the right is from the top of the sheet. (Sheet was under 32" in length)
