So I am on vacation in Florida......
tattoo.dan
and of course something has to go wrong...or maybe...
We are running flexi 10 and a graphtec plotter...
my employee says when he sends a job, the plotter goes through the motions like cutting but doesn't cut....
is there a setting to just trace that he turned on by accident?
any ideas would be greatly appreciated!
Mike Paul
Super Active Member
Could be the blade holder screw loosened.
Also, is he sending the pressure from the software or from the plotter?
HulkSmash
Most likely the blade has fallen out, or sunken it
tattoo.dan
Yeah, blade holder was first thing I had him check...just called to have him check the actual blade and it is good.....idk...I do appreciate the suggestions guys..
tattoo.dan
yup...just like he said...goes right over the vinyl like it is cutting, blade moves up and down like cutting, but doesn't even touch the vinyl....weird...
tattoo.dan
here is a vid..if i attached it right....conditions are set on the plotter itself and they are right...idk
  • vid.zip
CS-SignSupply
Make sure the blade holder is seated properly.
If the plastic hook is under the lip of the blade holder, it will stop the blade from contacting the vinyl
See image
milchad
It could be in pen touch mode. I use cutting master 2 software, so I'm not sure how you would correct your issue.
Pat Whatley
Downforce in production manager turned to zero or the incorrect tool selected. If the settings on the plotter are correct and the blade holder is installed correctly that's about the only option you have left.
tattoo.dan
Hey Pat, I had him send me a pic of the display on the cutter and all of the settings are right.....and that is where the downforce is set....is there some place in pm that I would have to have it set as well?
Pat Whatley
You can adjust the downforce in PM and those settings will over-ride whatever the settings on the actual plotter are. I know the display on my Summas will look correct but when I send a file they will change to whatever the PM settings are. As soon as the job is finished the Summa display will go back to normal.
At the CUT/PLOT screen tell him to go to OPTIONS then click the EDIT button. Tell him to uncheck TOOL, PRESSURE, and SPEED.
If you change your options in PM Flexi will save them with the job. If you open that job later it will use those settings. It's the lazy way to change things and it will come back to haunt you later. I had an employee who used to adjust his downforce in PM as the blade wore out. 10 years later there are still times I will pull up an old file he did to get a logo from it or to make a change to the old sign, set up and cut the vinyl, and the downforce will adjust itself and either be too light or too heavy. It only happens about once a month, not often enough to remind me to check it, just often enough to be a pain.
tattoo.dan
OMG! I think he did just want a day off!!!! lol
finally got the pic I asked him for YESTERDAY!
had to ask the secretary to do it for me....WOW
Exactly what Bobby had said, but I talked to my worker yesterday and he ASSURED me it was UNDER the clamp....
awesome...
thank you all so much for the help and suggestions.....
bad news is storm is here now, good news is I am still in Florida and I am done dealing with employees for the day! Thanks!
