SP540V Feed Adjustment Doesn't Work
Stagecraft
When doing a print/cut test, adjusting the feed setting changes nothing, I get the same results every time even if I make an extreme adjustment.
The print/cut results I get are acceptable (just) but not perfect.
I am able to change the scan settings and get perfect registration on that axis.
The machine is clean, encoder strip is clean, pinch rollers are good...I'm stumped.
