Spot color foils on clear
artofacks1
Currently I am using spot color foils on clear vinyl. I learned that the white is solid, 100% solid. I use artic white. I printed a job that was yellow, white and blue on clear. The first print I printed yellow and the blue straight to the clear vinyl. I fast learned that the blue and yellow was see through and not 100% solid print like the white. Therefore, the next print, I printed a white flash with the artic white. Than printed the yellow and blue on top of it. Than I got the yellow and blue that i wanted.
Long story short, is there a group of gerber foils that are 100% solid like the artic white foil that will allow me to print directly to the clear vinyl with out having to print white on it?
Thanks,
Robert
Fred Weiss
No. Only black and white are opaque. All other foils will color shift unless they are printed on white vinyl or foil. The two available solutions are to setup your jobs with with chokes and spreads to minimize overprinting while trapping your spot colors or to print using process color foils which do not require chokes and spreads because they use percentage fills. Either way, if printing on clear, you still will need a white foil base coat.
artofacks1
I bet a foil line that was opaque and had no need of white would do well in sells. I guess I better stock up on white!
CanuckSigns
From what i've heard from our suppliers, less and less people are using their gerber edge machines, I don't think you will see much R&D going into new products for it unfortunately.
artofacks1
Are the ink jets catching up or the latex ? How are people doing the clear white and chrome metallics now a days if not on a thermal printer?
