Starting a Laptop/Mobile skin business, need help please
Maxi
Dear All,
First of all, I would like to thank you all for sharing information about this industry, I'm just few days new to it and I already know a thing or two because of the great posts you guys posted here.
I'm planning to open a small business to sell skins for mobile phones and laptops in multiple sizes, I'm aiming for the best quality possible so I would appreciate your support and advise on the following points:
1- The Printing material: I have made my research in this forum and found that most users are recommending either 3M IJ180-c and Oracel 3164 Gloss, but which one is the best?
2- Printing: What is the best printer to print on these materials?
3- Cutting: What is the best cutter to cut my designs based on the sizes I want?
4- Software: I plan to mainly use AI, maybe CorelDraw, is there any other software that I should know in order to use the printer and the cutter? or they are already compatible with the above two software? I see that some of them are.
5- Lamination: Does the materials I mentioned already glossed? I never printed one myself, I always buy them ready and they look awesome and glossed, do they gloss them after printing or its printed like this? if they gloss them then what's the best machine/device/material to use to gloss them?
I would appreciate your support, even if it's small, remember that every word you said will be good for me.
Thank you in advance.
Best,
Maxi
Fatboy
Welcome Maxi......why don,t you contact a Roland dealer in your area.I am sure they can answer all your questions!Go and have a demo.I think that is the best.:Welcome:
Maxi
Thank you very much :) you helped me by this because I didn't know Roland :) it seems like a good company that makes good equipments and stuff.
Is this their website? http://www.rolanddg.com
Will look forward for more information and especially advise.
Best,
Maxi
Salmoneye
A roland might be a good choice but you would have to sell tens of thousands of these to justify such a purchase. Why would you not hire your your printing of your designs?
Maxi
Thank you Salmoneye, you raised a really important point which is the cost, I believe you are right, I should hire the printing of my designs, but I would like to have your help about the below questions because many printing companies will tell me that they will provide "best quality" and use my lack of experience in this field.
1- What type of printing should i go for? digitial? any specific needs i should mention?
2- Should I provide them with the material? what material do you recommend of the two i mentioned? will it be cheaper if I buy the material or i leave it all on them? or that will depend on my negotiations?
Maxi
jscarl
Welcome from mid Michigan. I do not do any printing, but it sounds like you are getting very sound advice.
TheSnowman
You just need to do some research on how a sub works. You would send them your design, and they would print it on their material. If you are subbing it out, your project is going to be very tiny compared to most jobs that they print, unless you are just doing thousands and thousands of these.
And yes, digital is the only printing for vinyl unless there is some kind of dye-sub out there, but I don't know anything about that. Pretty sure for pressure sensitive vinyl, you are only able to go digital.
BigfishDM
I can tell you that if your about to start up a business you should write out some goals your trying to accomplish and also a good business plan wouldnt hurt either. You should definetly start by out sourcing the printing. The most important part of a business is the client so have you figured out how you plan on getting business in the first place yet?
SurfaceSigns
Welcome from the Canadian West Coast.
You'e gotten lots of great advice here so far, I'll try to address a few questions that haven't been answered along with some advice.
The gloss level is determined by the material the printing is done on (if you don't plan on laminating the prints), or by the type of laminate applied. Both are available in everything from matte to high gloss. You can also get laminates that have different textures to add to your designs.
If you are planning on selling the skins for the end user to apply, I would definitely use a material that has air release channels in the adhesive (3M, Oracal, Hexis, Avery, Mac Tac, etc all have suitable materials). This allows for an easier installation with no bubbles. I'd also suggest using a Cast material over a Calendared material, as the Cast materials are made to handle curves and such better.
As Pat said above, you really should laminate to extend the life of the skins. The laminate acts as a protective barrier for the print, both from physical damage and fading. Laminating also gives the print a bit more body, making installation easier for the end user.
If your are sourcing out the printing, there is no need to provide materials. You would simply spec what materials you would like used. Most of us tend to stick to brands we like, so for short runs, you may have to go with what ever that shop uses. For larger print runs, I'm sure the shop would have no problem sourcing the materials you spec.
On the Artwork side, you can use pretty much any of the major design software titles such as Photoshop, Illustrator, Corel, etc. Basically, as long as it can produce a PDF, EPS, or AI file, you'll save a bundle on having your print source prepare the file for rip and print. Jpeg, tiff, and other raster file formats can be used, but they need to imported into a vector program to produce the cutline for the skin. If you are outsourcing, I would touch base with them to find out what their file requirements are.
To get into this on your own, you are going to need a Printer/Cutter (I'd personally suggest Roland), a Laminator, Shop tools and supplies, a work bench, an opening inventory of digital media and laminates, computer, etc. If you were willing to look at used, you could probably get up and running for under $20,000 all in. From there, the sky is really the limit in this industry. You need to look at how many skins you feel you can realistically sell, and weigh your options.
Keep in mind, the skin segment is a very saturated marketplace now. The margins seem decent, but looks can be deceiving. With a product like that, the marketing is paramount to your success, and may cost as much or more than it would to produce the product, initially anyways.
Maxi
Thank you very much, I believe it will be better for me to outsource it, I will do more research as per your recommendation and go for the best option.
Maxi
Welcome from Canada, Maxi.
Good points made in the first couple of posts.
Materials: you'll need something fairly soft and pliable (like 3m 180cv3 - not sure that the 3164 would be great for this).
Equipment: you'll need a solvent printer/cutter (such as a roland, mimaki, mutoh) or a printer and a standalone plotter. Depending on your price range, all those companies have different levels of equipment.
I don't know much about skins, but I think it's fairly safe to assume that they are laminated since they are constantly handled. For this you will need a laminator (GBC, Royal Sovereign, Seal etc...there are several budget laminator manufacturers but I'm not familiar with them) or a Big Squeegee which is sold by a merchant member on this site.
Software: Adobe Illustrator or Corel are both fine for this - you can set up your designs with cutlines in both these programs. Your printer will come with a RIP program which will send files to your printer/cutter or printer and plotter. Fairly simple to learn the basics - without getting into color management and profiling.
Outsourcing: This would definitely be the most cost-effective way to go about this unless you have $40,000 +/- to spend on start up costs. Not to mention all the time and materials you will go through before you can actually get graphics going out the door. Not discouraging you from starting up your own thing by any means but if you wanted to start by subbing out the actual production part of it, you wouldn't have to tie up any money at first.
The way it generally works would be you set up the files as you want them, send them to the company that will be producing them, and pick them up when they are ready. I'm not sure how all companies work but I'm sure most would prefer just to use their own materials. Plus they should be able to point you in the right direction as to which materials to use.
Hope that helps,
Pat
First of all, thank you for taking time to respond to my post, i really appreciate it!
As for the equipments and the material I believe I will take your advice and find a place to print it for me as I don't have that large budget now.
As for the material, I want to produce skins like the ones on this website for example http://www.gelaskins.com/ they are using a 3M material that's for sure but I'm not sure which material exactly they are using this is why I'm just guessing, i've ordered samples from this website and many other and on the back of the sticker (skin) there is only "3M Controltac" written but no mention of the exact model, any idea on what this can be? is it the one you mentioned? I'm sure it's difficult for you to know without thouching it or seeing it in real.
I have a good business plan and I'm nearly sure that it will work really well with the specific audience i'm targeting, I hope things goes well.
Thank you once again for everything.
Best,
Maxi
Maxi
Thanks for your reply, I will definitely do this, and I will outsource at the beginning, I already have a business plan with goals and objectives, it's just the production part that I'm lacking information of, and with your help and the guys here I'm sure I will be able to know the right thing for me and determinate the cost associated with it.
Best,
Maxi
bigben
Not a newbie
Bonjour Maxi,
I can help you with all of your questions. You just have to send me an email and I speak french too. b.dulude@ssbgrafix.ca I also know your market in France since I sell some stuff there.
Good luck!
Benoit Dulude
Maxi
Thank you very much for taking time to write all this useful information, I believe after reading your comment and Pat's comment as well as the others my only problem is to find the right material to use, many printing shops in my area will claim that their material is the best, and they may even provide me with 3M material but not exactly the one I need, they may provide a more expensive one or a one that is not suitable for my business.
I plan to sell the skins so I agree with you,I should do lamination, is there a type of lamination I should use? or it's only one time and I can tell the shop "I want lamination for the skins"?
I have a very good marketing plan as well as PR so I'm sure I will do good after i figure out what material/quality i need and get things going.
Thank you and all the Canadians in the west coast!
Regards
Maxi
