Suggestions Summa D120 SE
Alan Menhennet
Hi Everyone
I have the opportunity to buy a Summa Cutter. The Summa D120 SE model.
I actually have a Mimaki Print & Cut but would like to add the Summa for my Titanjet (Cheap Printer) to produce labels (Print on the Titanjet & Cut on the Summa).
I know this is an older model. Would it still be wise to purchase it or should I rather go for some local imported Chinese cutters?
Titanjet uses flexi. Would i be able to get the Flexi cut software for the Summa as well or even something like Signmaster which I really enjoy using.
Ive attached pics of the Summa cutter to show the model.
iPrintStuff
Prints stuff
What rip do you use on the mimaki? If you really wanted you could cut stuff you’ve printed on the mimaki on the summa too. Keeps your printer for printing!
Alan Menhennet
I use Rasterlink's Finecut. Yeah thats also a good idea.
Im not too clued up on how I would go about it though.
Usually I tile the image in Corel then Export using Finecut straight out of Corel. It then saves both files print and cut in the hotfolder. So when I open Rasterlink the file is there ready for cutting.
Signmaster i have to save a pdf to print and seperately send the file to the cutter as you would with a desktop printer to cut.
iPrintStuff
Prints stuff
I just use the presets in onyx so I could be wrong here, but I believe summa also has a plug-in for their marks. Should be the same workflow. I’ll reiterate that I’ve never actually done it but there should be a lot of resources here or online.
We have a mimaki print and cut and rarely use the machines cutter any more. The summa is MUCH quicker, more accurate and it means we can keep the mimaki printing.
Alan Menhennet
Thanks, ill have a look around and read some more.
But in short would you say this would still be a good buy even though its an older Model?
The agents for Summa here in South Africa said that it looks like a really old model... And would suggest rather buying a newer model.
But in the same breath they told me Summa cutters last for years & years...
I have a limited budget so thats why Im leaning towards this cutter.
FrankW
Even an older Summa is a better choice than the common low cost chinese cutter. But the contour cut functionality of the summa cutters have significantly increased with the newer models and OPOS X. So I would think about a newer Summacut or S-Class with OPOS X. Flexi regularly supports contour cutting with summa.
PHILJOHNSON
Sales Manager
I would have to agree with Frank that an older Summa, even the SE model you mentioned above, would be a much better alternative to one of the cheap Chinese options. If you can swing one of the newer Summa models with OPOS X that sensor will be able to sense the marks with more consistency, especially if you are using a glossy laminate.
Let me know if I can answer any questions for you about the different Summa options and I would be happy to help however I can.
Best regards,
Phil Johnson
Airmark Corporation
(800)527-7778, ext 112
philj@airmark.com
Alan Menhennet
Best regards,
Phil Johnson
Airmark Corporation
philj@airmark.com
Thanks for the response. This must be a silly question but I cant find any info on the SE version... Does it have and "optical eye" to detect printer crop marks.
The seller didnt use it himself. His employees did years ago so he cant even answer me
Alan Menhennet
Thanks, ive read great things about the Opos X technology
Udesignz1
I does have opos reader... never tried it before
vondegroot
Hey just trying to do some contour cutting on a new to me D120, and I noticed the spring is just hanging! I'm about to take the head off to inspect, but thought I'd drop the issue in here for the experts :)
