Need Help Titan 3 Issues...
Amos_McFly
I have been using a Titan 3 from US Cutter for 3 years now. I don't hate it, but there is one major issue I have never been able to fix or figure out. On round shapes I can't get the start and stop points to line up. I've just had to deal with it and fix what I can. I've attached an image of a test cut I did to show the problem. If it is an equipment issue, I understand I should have spent 3 times as much on a high end cutter and some day I will. If it is a settings issue and I'm just not getting it right, then that's where the veterans might be able to help. I appreciate your time!
jimboeejit
have you been in here to settings for cutter?...looks like you need to adjust force and overcut or similar
Amos_McFly
Yes, I've been there a number of times in the past, but had given up on it getting better. I will revisit the settings again. Just wanted some professional input first. Thank you
Amos_McFly
Update... I revisited the settings and did a calibration, which I've done a dozen or so times before. This time it worked well and as far as I can tell, there are no more off-cuts.
Thank you!
