UJF-6042 MKII UV LED Weirdness
Smoke_Jaguar
Working on a recently acquired UJF and got it all up and running for a bit. Started getting temperature messages for the LED unit. Pulled out the thermal imager, looked good. Heat was being pumped out, filters were all good. Looks like the unit was replaced very recently as the black plastics were pristine. So, booted into service mode and checked temperatures. UV LED 1 -73C, 2 26C, 3 26C and 4 26C. So, yeah, definitely an issue on sensor 1. Checked service manual and it showed the rough layout of the LED board and connectors looked good. Checked resistances and only about 2 ohms on TH1, the others were a typical 70K ohm for a thermistor. Looked at the board and TH1 was a 0 ohm resistor for some effin' reason. So, after a bit of thinking, I fired up the other UJF that I know works fine, and all 4 sensors had a reading of ~25C/ambient. So, yeah, not sure if there was some strange revision, or if the board was a total screw-up on Mimaki's end.
Not sure if mine was just special, or if there was a bad batch. Mainly just posting in case someone has a similar issue. If you've had this happen, feel free to chime in. Felt like I was going bloody insane.
