Uv ink remover
Polly93
Is there any product that can remove cured uv ink off plastic if the product needs to be reprinted? Thanks!
signheremd
We have had good luck with Denatured Alcohol (available in most paint departments). Spray it on and let it soak, keeping it wet, for about 10 to 15 minutes, then wipe with paper towel or plastic razor. Works best on glass, keep it wet until ink looks krinkled, then pull it up like a water-based decal.
