Valuejet 1638x bi-directional adjust not working
Vellu
I have been trying to adjust vj-1638x bi-directional, but it doesn't seem to work at all.
No matter what value I put in, results are allways the same. Maybe it has something to do with this "new" DropMaster technology...
I have adjusted bi-directional with older mutoh's without any problems but for some reason in this machine it's not working...
Anyone else had these problems?
What kind of issue are you having? Blurry image? Ghosting? Post a picture, It may be a different alignment that is off.
Any idea about this lines? After changing 1 head of Mutoh VJ 1638x the printing is not fine especially green, orange, cyan colors...
They also change the small boards and data cable connected to the 2 heads...
henryp
If the print was fine before 1 head was replaced, it is more likely that head alignment, either physical, electronic, or both, is causing the problem you are having now
