Question Versaworks no matter what preset it will not print bright red
Purehobby
How can I print bright reds in versaworks? Seems every preset prints way off colors
BN-20 printer, eps files done in adobe Illustrator or Photoshop and printed in versa works.
Media Type Generic Vinyl 1
Color Management ive tried most of the presets and im not sure how to make profile and where to load it in at. Can anyone help with that?
Terry01
Test print, printer used, program used prior to sending it to Versa, would all help. Save the file as a PDF, add it as a job, and let us know how you go.
The Duke
Printed this with my Roland VP-540. I can match colors based on the CMYK or PMS codes. Most digital printers are bit different, so its good to have a reference to match a clients color.
I took my PMS book and matched the colors of this print. was a bit different. So its much easier to print this then use it as reference, than fully trusting the color code will come out perfect with your printer.
Also, another thing to check is the profiles you are using for your printer. make sure it has the correct material set and play with the settings.
  • PMS_CMYKPressSheet.pdf
Purehobby
Printer and inks would be helpful
victor, i think my answer stands on it's own, regardless of what printer or inks.
there could certainly be more to it, but, if we were playing jeopardy i would stick with my original, answer
none of my printers gave me a "fire engine red" until i broke out the Xrite I1 & did the work
Purehobby
Roland Inks, BN-20 and I have adjusted color management down from 100% on all but still coming out dark red. Picture attached
weyandsign
What are the CMYK values of your red? It looks like it has some black in it. Color management, I think MAX density U.S. works best
