Vutek printer & EFI stretchable inks
henryz
Hello, we are looking to get a Vutek flatbed printer to print and thermoform pan faces. I see EFI has ink specially for
this application and I wanted to see if anyone if familiar or seen this and how effective is it. Will the illumination be acceptable? Oce was coming out with something similar several years ago but it was not that great at the time. This can save a lot of time vs back spraying process.
Thanks in advance
Henry Z.
Jason DeLuca
If you're still interested in thermoforming inks on a flatbed printer you can check out swissqprint.com
They have an series of inks specifically for that application
wunder
search this ?.......use MGF Ink from INX/Triangle
Datasheet find on INX/Triangle for MGF inks...have fun
biggce55
Whatever you do, stay away from Polymeric. We switched back to them after Nazdar stopped making a flexible ink after EFI bought the patent on the Flexform ink a few years ago in our Jeti 1224. We have lost 5 heads with the exact same issue since switching back to Polymeric where the ink is eating away at the side of the head causing a blow out. Polymeric stated our ink pressure is too much on the machine, but 2 techs that came to our site state its Polymeric ink is the issue, not our machine.
