Where can I buy 5x10ft or larger 1” Phenolic Sheet?
Zendavor Signs
Mmmmm....signs
Would acrylic work? I’m not real familar with phenolic. What are you using it for? I would try Sabic or A&C Plastics, they carry many different types of weird plastic materials.
Sent from my iPad using Tapatalk
PaulyD
DIY CNC Hobbyist
rjssigns - Yes, I already know that it is going to be expensive. Which manufacturers? That's the info I need.
Zendavor Signs - No, Acrylic won't work. Our CNC's vacuum table top has run its course...need to source and re-plenum this 5x10 table top. Phenolic was what was on their before. I already have a price from the OEM but believe that it's padded on-top of the actual price of the material. Just need to understand who the resellers are of this product that even the OEM would source from. I will check Sabic and A&C. Thank you in advance.
CanuckSigns
Are you sure it's phenolic? My understanding is that the dust created when phenolic is cut is carcinogenic, I know in the engraving industry, electrical tags used to be made from phenolic but they switched away to acrylic based because of the health concerns.
If it's for a cnc router table top, most people use MDF sheet and throw it away when it gets worn.
