White ink not pumping to reservoir
Border Press
I have an Arizona 318 GL flatbed. The white ink reservoir got low and has not been able to fill back up. I can hear the pump trying to work but no ink flows out. I've replaced the ink filter and when I open the bleed valve nothing comes out. Would it be the ink pump or could it also be something else?
CMYKENGINEERING
Probably the white recirculation valve has died. Original OEM part number is
3010114396 KIT-WHITE RECIRC VALVE O:3010109356 O:30 but the price is $1,078.79
Several of our customers have no problem with a Chinese made valve.... the design isn't great but its working fine and cost about 50$
Border Press
Thank you. I'll check it out. I've ordered that part and the ink pump. Hopefully this works.
tollerdad
You will find that the bad pumps usually have what looks like graphite falling out of them. I have replaced a couple white pumps on my 460 but no CMYK yet. Also just ordered some the new recirc valves. Hopefully they work, my current ones are getting flaky.
Border Press
Thank you guys for the info. The problem was the recirculation valve for the white ink. I replaced it and now it works great. I did not need to replace the ink pump so I sent it back.
