Need Help Window Perf and Laminate
wleong
Is there a way to eliminate air bubbles when applying laminated window perf to glass? I’m told the bubbles will eventually go away but the application does not look very good so far.
Sent from my iPad using Tapatalk
ikarasu
Practice. We dont get air bubbles when we laminate... If we're not paying attention there might be 1-2. Take a pin, not a knife... and pop it in the center. Then work your way from out to in, and the bubble will go away.
The bubbles wont go away on their own... you need to pop them. Once you get used to applying perf with laminate, you shouldn;t get much, if any bubbles though.
