Wrap vs Cut Vinyl for Windows?
daenterpri
We have some lower window panels to wrap on a building in plain white. 56" x 27" panels. The customer wants every other panel to have text cut out of the wrap panel. Initially I was going to do these wraps with regular cut vinyl, wet install.
However, because they are low to the ground, and because they have to be transfer taped because of the embedded text, It's a bit of a pain. Is there any reason why I wouldn't use a good wrap vinyl instead with air egress adhesive and just do a dry install? Was thinking Arlon 6100XLP digital, unlaminated.
Is this an acceptable way of wrapping windows in white? :)
Thanks!
eahicks
I use Air Release (IJ35 or IJ180) all the time for plain white text. Install time cut in half. No bubbles, no liquids. Do it.
myront
CorelDRAW is best
Ditto on that here too. Might also consider what the customer expects to see from the other side. "Clear" adhesive will allow white to be seen from behind whereas other vinyls can be had with a "blockout" which is gray.
T_K
From my experience, you lose the benefit of the air egress the moment you put application tape over top.
