wrapping text on a cylinder
letterman7
Probably covered before, but can't find it through the search engine; is there a way to "wrap" text on a cylinder in X5? I could probably edit each letter individually, but that would take a bit of time. I also have Illustrator c3 that I don't use much if there is an option in that program.
letterman7
Not quite, John. Corel has the fit text to path, I'm looking for the text to wrap around a cylinder.. i.e. looking at a cylinder head on, with text upon the surface, the text would "disappear" around each bend, like a poster on a subway pillar.
Envelope tool won't distort correctly, De.signs..
Custom_Grafx
I don't know about in corel, but I've done that in Illustrator.
It's been a while, but from memory, you need to make a symbol instance out of your text or whatever you wanna wrap around your shape...
The catch is, that you need to make your cylinder or shape, using the 3d tool in Ai. I believe the feature you're after is called something like "map art" ... or sthing along those lines. You can map art to any surface of your 3d shape.
signage
Could you post an example of what you are looking for?
Text on any cylindrical things I look at doesn't appear get smaller as it is seen going around it.
letterman7
I never said the text got smaller, just that it appears to disappear. But yes, the 'convert to bitmap' option that Pat mentioned sort of does what I'm looking for, though it does tend to distort the image (and you lose the vector format). For the time being that will serve my needs (thanks, Pat!) until I can figure out a decent distortion-free path.
