Wrong inks
heyskull
This is an ongoing thing which I am trying to work out.
If I was supplied Eco-Sol Max 2 instead of Eco-Sol Max 3 and used it in my machine.
What is the issues and problems I could encounter?
I think my supplier has sent me the wrong ink and it is causing issues.
SC
MrDav3C
Initially I would expect the wrong ink to cause a noticeable change in certain colours & possibly banding / poor quality in prints.
I would then be concerned if the wrong ink could clog the dampers and cap tops or even damage the print heads due to the different levels of solvent potentially in the ink.
I would be looking at print quality, if there is ink where there shouldn't be i.e. pooling out of the head during printing or overflowing on the cap tops.
Admittedly this is complete speculation as it's not something we have ever done and I don't know enough about the differences between Eco Sol max 2 and 3 to say what it could do & obviously any potential issue could have been there underlying anyway!
heyskull
A while back I had a set of inks although marked externally as Max 3 when installed came up as "wrong ink type".
The supplier reckoned "the wrong chip had been installed" and sent others out to replace them.
My ink issues are as if some inks are not mixing as they should and leaving a mottled effect.
This mostly shows on anything with yellow in it.
SC
victor bogdanov
SC
Are these OEM inks or different brand inks?
Eco Sol Max 3 inks are compatible with the following machines:
VersaSTUDIO BN-20 Series Printer/Cutters – CMYK + White and Metallic Ink**
VersaCAMM VS-i Printer/Cutters – CMYKLcLm + Light Black, White and Metallic Ink
SOLJET XR-640 Printer/Cutter – CMYKLcLm + Light Black, White and Metallic Ink
VersaEXPRESS RF-640 Printer – CYMK Ink
I don't know for sure but it looks like these are Roland's version of the faster drying inks that Mutoh switched to. If that's the case, mixing them could cause issues for sure. Clogging issues.
heyskull
These are Nazadar inks on a RF-640 4 colour machine.
My nozzle test is perfect and it has been checked by a Roland Tech and it is printing and aligned perfect.
SC
SC
That does make it a bit different. 3rd party inks will often use the same ink and just change the chip for sure.
heyskull
Nazdar state they make a MAX 2 and MAX 3 ink.
On a further note.
I was on the US Roland Profile site and there only are profiles that are specifically for MAX 2 inks and do not show MAX 3.
The European site has the choice of MAX 2 & MAX 3.
Are MAX 3 inks not available in the US?
SC
victor bogdanov
Are Roland MAX 3 inks available in the US?
SC
looks like it
cornholio
Max3 was introduced in Europe, due to chemicals at the workplace regulations. They dry fairly quick. On the print medium, but also in the printer...
On introduction, they were also advertised to work on VP and SPi.
We had our troubles with DX4 machines and switched back to Max, or Max2.
The ink dries up in the black standard tubing of the DX4 captops. You needed to use captops with transparent tubing.(same as used for captops for DX7)
Overall, I liked the Max3 for it's clean yellow giving vibrant colors. But lately we had issues with this yellow clogging heads. We started switching back to Max2 for mor stable operation.
netsol
Might be time for thorough flush, and "inking up" with known good (correct ) inks
IF NOT...
Plan B would be something similar to my daily routine.
Wet the felt in captop(s) with proper cleaning solution at end of day, BE SURE the head is properly seated on captop TO AVOID INK DRYING INSIDE THE HEAD and run a cleaning cycle every morning
