yard sign
HDvinyl
Trump 2020
Less is more? Or should I add some bells and whistles?
afarraway
Less is more always works. The key is making sure all the right info is there and it has a call to action. This sign has a touch of mystery, which my be in itself a call to action because people will want to know what it is.
Initial thought, health related/quitting caffeine. What is the purpose of this sign; to increase web traffic so customer goes to website to find out more/ sign up?
Also, is it for a 24x6inch coroplast "rider" used with a step stake?
reQ
I usually keep it simple... sometimes i would add some borders like that.
attachment.php
Craig Sjoquist
I would reverse that & use red background for main copy & use white border & outlines if ya must, white background for .com copy.
Unless the banner will be going in front of a dark area
Marlene
with super long address can you do it upper and lower case so it reads a little easier? KickTheCaffine ?
oksigns
kickthecaffine.com should be all the same size, but keep the font the same. This makes it easy to read. Marlene makes a good point about first case caps.
The stroke is very distracting. So you can keep it all white, under the red BG, and then alternate it with white bg bottom and red email address.
I thought you were gonna try it with some bells and whistles ??
It's all hard to read and will most likely be overlooked by just about everyone it's meant for. If they're trying to kick the caffeine addiction, they can't zero in on that mess. :doh:
Craig Sjoquist
Next I would just use red banner.. name.com only... also with red background white letters only if outline white outline outside letter, much thinner would read better.
Beside if you go to the website further info can be sought after, the point is ya gotta get them there 1st.
2B
this
the E-mail is pointless if they are already being directed to the URL
PS: the font on the current URL is hard too read
