10" Octagon Coro Blanks
Discussion in 'General Signmaking Topics' started by scarface, Jun 20, 2010.
  1. scarface
    scarface Guest
    Hey guys, I have a customer needing 25 single sided, 1 color with stakes 10" Octagon yard signs.
    I looked in stouse and they have 9x9" and offer 125 pieces and up.
    I usually use harbor sales for my supplies but not sure if they can cut to shape coro for me (it's Sunday so i can't call)
    About posts, I'm not sure what to do for these, I use 2 wire stakes.
    Any ideas where to get these?
    Thanks!
  2. sjm
    sjm Member
    479
    Think your sol, octagon signs, just thinking of the waste even for 1 colour on a Sunday you'll be paying a premium.
  3. Malkin
    Malkin Very Active Member
    2,193
    26
    48
    Feb 11, 2009
    Augusta, ME
    We have a 24" guillotine that is basically like this one:
    http://www.amazon.com/General-Binding-Corporation-TRIMMER-CLASSIC/dp/B000SBETDK
    although ours is at least 30 years old.
    It's great at chopping 4mm coro, just keep your fingers out of it. For signs like this I would first cut the 10" signs to squares, then tape on a jig to chop off the corners.
    For just this one small order you could just rig up a jig from excess coro & cut them by hand on your workbench.
  4. scarface
    scarface Guest
    nvm im just going to tell the customer it's a minimum of 125 (stouse) or he can choose a standard shape if he wants only 25. Thanks anyway guys.
    UPDATE: guy said he got them for $8 each from some guy so i told him that's fine but i won't be doing them that cheap because the time i'll have to cut them down and hopefully they are the exact same isn't worth $200 IMO and outsourcing them to stouse would be a better match, working smarter not harder
  5. Gino
    Gino Premium Subscriber
    33,516
    2,399
    113
    Jun 7, 2006
    PA
    scar.....
    This whole thing makes no sense. With a jig in place you could cut these out in about 15 minutes or so. Where do you come up with these high quotas [125 pcs] ?? This whole setup can only cost you maybe about $75 or so. What's with the 125 minimum ?? Are you not checking out all of your options or something ??
  6. scarface
    scarface Guest
    the 125 is if i used stouse, I'm not worried about it. Take some, you lose some.
    I would have printed the design, mounted onto the blanks but every cut had to be on the money for them to line up right and i just think it would have been easier to turn the job away IMO
  7. Gino
    33,516
    2,399
    113
    Jun 7, 2006
    PA
    Well, since this thread is out in the open, I won't go into how to do this, but I think you just turned away a rather profitable job. Maybe you think it was beneath you, but when you consider your material costs and time...... $8.00 is good. You could've made some good money in less than an hours time.
    If you want to know... PM me.
  8. Mosh
    Mosh Major Contributor
    5,809
    41
    48
    Oct 19, 2009
    Nerbaska
    You do know the formula for doing octogons right????? How much to cut off each side...old signman trick.
  9. Malkin
    2,193
    26
    48
    Feb 11, 2009
    Augusta, ME
    Nope, but I do know how to make an oval.
    So, Mosh, how do you make an octogon?
