1614 cleaning questions....
Wrapdup
How often should you run cleaning fluid through your printer?
also, printer is set to do the auto cleaning after XX amount of minutes.... if we have a couple prints in a row, and it happens to be the time it wants to do the auto clean it will every time, without a doubt clog one of the colors once it goes onto the next print..... stop it, clean one more time, do a nozzle check and will be fine again. its very irritating.
alfred
I run cleaning fuild i time in 6 months in my 1614. You have to see if your cap seals good with your print head so the cleanning is effective, you can check it by pumping with a syringe .
