1624x Media End
Kelsey Adams
Trying to print on 24” wide reflective material. When it goes to do the media initialization it comes back with media end. I tried setting the vinyl to the right and in the center and no difference. I put tape over the sensor in the back as well and that didn’t do anything. Anyone print on 24” material before and know how to set the printer up for it?
Ssignature
Scott “Not Bob” Steinecke
The media is lifting off the preheater behind the pinch rollers. Try feeding slack off the front of the roll to create a loop. Be sure to maintain it, or your problem will reoccur
Ssignature
Then the rear/edge sensor calibration need to be done. Prior to that if possible, clean the rear sensor with a tech swab and a little 91% alcohol.
  • 1624 Rear-Edge Sensor Calibration.pdf
