3m 2080 Flip Cast film Printing????????
Discussion in 'Materials' started by DRPSignsNGrafix, Sep 23, 2020.
  1. DRPSignsNGrafix
    DRPSignsNGrafix Very Active Member
    Has anyone tried printing on this film? I think i might work really cool for a personal project. Didn't know if anyone has had any luck trying to print on it.
  2. P Wagner
    P Wagner Very Active Member
    1,914
    80
    48
    Aug 16, 2006
    San Diego
    Not sure how this could work, as this media has a removable film on it's face which is intended to be removed only after installation is complete.
  3. DRPSignsNGrafix
    Yes it does. However it's there to help with install. My thought process is to remove it and print on it. Then maybe Laminate, haven't decided yet. Then install. My question is more to the wondering if anyone has tried and see how it accepts the ink.
  4. jfiscus
    jfiscus Map Wraster
    3,192
    239
    63
    Apr 2, 2009
    Cincinnati, OH
    I would wager that it prints pretty decent with that film removed on a solvent printer.
    I've removed the film from chrome vinyls and printed onto them with good success. Just try not to touch it and keep it clean.
    If you're doing a long print run you might want to remove the film with your laminator (kinda like reverse lamination).
  5. SignMeUpGraphics
    SignMeUpGraphics Moderator
    1,327
    274
    83
    Apr 11, 2012
    Australia
    We've printed on 1080 plenty of times. Haven't had any troubles with it. I'd assume 2080 to be similar.
  6. I've successfully printed on 1080, laminated, and contour cut. It accepted ink like any print vinyl. Was on a vehicle for two years before it was stripped to be sold and looked just as good as day one without any adverse effect to the adhesive.
    I run a Roland VS-640.
    As far as the film on 2080, it can be removed prior to installation/printing. It's to help reduce scratching with the installation.
