Suggestions 3M CONTROLTAC ECONOMY WRAP VINYL
Signchief
I am thinking about using this film to wrap a Kia Soul, I noticed in the description it states that it is not as comformable as 1080 so I'm a little worried about using it and hoping for some feedback from someone that has used it before. Thank you.
eahicks
Should be fine for short term wraps. Just don't expect ease of install on a serious curves, but flat to gentle curves would be fine.
Z SIGNS
Ever hear the term "you get what you pay for?".Wrapping with the best material is hard enough.What kind of results are you expecting with the cheaper stuff?Use the best materials you can get and charge accordingly.Send the jobs that can only be had if you are low priced elsewhere.
Gene@mpls
It sounds like Oracal 3551gra, it is a modified 'High Performance' calendared material which we use a lot and have had great luck with. We do not do wraps BTW.
