I suggest whatever is available!
Avery 1405 is a concrete, orajet 3954... Brightline makes one... Honestly, the best bet is to call Grimco or fellers or whomever you buy from and ask what they have in stock.
180 LSE should work. Anything with a high tac adhesive would probably work.
In SoCal maybe it's fine. I'm in Vancouver, we did it in 5 celcius, which is 41f - and ours was an under ground... So the walls were cold to the touch. It makes the glue brittle, even if you pre heat it...
We did go back with 8624 once we got it a few weeks later, installed in the same temps / conditions and everything stuck. 8624 has a really high tac adhesive to it, so I think that's what made the difference.
